GPS-RTK2 Board - ZED-F9P + GSM
i would like to know the compatibility of this GPS module with the Sparkfun GSM products for acquiring position corrections. Are they compatible, has anyone tried anything like this before?
Thank you in advance!
Greetings. Thanks for posting on the forums.
I can’t recall anyone at SFE combining say the GPS-RTK2 with the SARA-R4 for position corrections, however, I feel like with a central microcontroller such as an Arduino you could certainly use the data from both devices to try and collect the data you are looking for, however, we do not have any data to assist with this application. Both products are designed by U-blox.
https://www.sparkfun.com/products/15087
Maybe consider posting on the Ublox community forums to see if folks have combined the 2?
https://portal.u-blox.com/s/
I hope this helps.
Hello, thank you for the reply,
i didn’t state the question well. I meant with the use of a microcontroller, has anyone tried something like that before and because there are certain providers that sent the corrections in which form do they send it. Thank you
