Graphic LCD Backpack
I recently purchased a 128x64 display with a graphic LCD backpack. I was wanting to use the library that was linked on the Sparkfun page. The library says in order to use it, I should flash it with a hex file. Do I need to or is this the same firmware as spark fun? If I need to, how do I do that. Can i do it with my FTDI.
thanks,
Eric
Eric,
SparkFun Tech Support does not monitor this forum. So, if you don’t get an answer here in a couple of days, I suggest you e-mail: techsupport@sparkfun.com.
Eric
