Hi all,
I once had a project using a heart rate receiver (for use with a usual heartrate transmitter). I used it together with a polar coded breast strap which used the polar coded feature.
the receiver counted the peaks of the transmitter’s transmission. the problem was, that the number of peaks per heart beat changed from time to time on startup (i guess because of the coding feature).
I now treid to get receiver modules from polar, but they should cost 25 € each.
I wonder if there exists any information/experience in setting up a heart rate receiver which can handele the coded polar signals?
thanks
Alex
