heating pad
Hello everyone!
Im new to play with electronics.
Im Dan and I play with heating pad but I have one problem.
When charging stops blinking the pad is cold again and when battery is still charging heat is hard to feel.
What I done wrong to make it working?
I want it to heat on battery, and make on/off button, what I missing? Please help if you can.
Best regards,
Dan.
http://i61.tinypic.com/2iqcy36.jpg
speedyexe:
Links to each of the items in your pic. I suspect that the LiPo charger can't supply enough current to the pad *while* it's charging the battery. What level of current can your USB port provide ?
