I would like to send an advertising signal to my mobile phone using 6 buttons.
For buttons, I would like to distinguish between one-click, double-click, and long-click signals.
Can I send a signal only when a button is pressed?
I expect so… when NANO board do you plan to use ?
We plan to conduct development between June and July and mass produce 5,000 units in October.
How do I configure double-click and long-click by connecting to the “gpio” button?
Please tell me more details.
Part of the BLE-instructions are depending on the Nano board you plan to use. There is the Sparkfun Red board Artemis NANO, the Arduino Nano ESP32, Arduino Nano 33 BLE, and others. Which board do you consider? Double, triple or long click is easy… it is about the BLE…
in100 nanobeacon I’m going to use chips.
The circuit needs to be rebuilt. The main chip is
I will use “IN100-Q1-R-RC1I NANOBEACON”.
I would like to know how to implement “IN100” double click and long click.
I was expecting you would be using one of SparkFun’s boards. Why else would you raise this question on this forum? E.g. with the Artemis Nano is using BLE, you can create a beacon. (see attached). I do not know how you plan to use the IN100… Do not know that chip.
example22_ph_Beacon.zip (9.1 KB)
