I purchased a new board to check if the problem was with my Windows 10 installation or the board itself
With the new board, I get a port available for programming, but upload does not work with the following error:
An error occurred while uploading the sketch
No device found on COM9
(COM9 is the correct port for the board)
If I open the serial monitor, the board is sending the following:
A5PinSet_results_part1 5: 0
A4PinSet_results_part1 0: 1
A4PinSet_results_part1 1: 0
A4PinSet_results_part1 2: 0
A4PinSet_results_part1 3: 0
A4PinSet_results_part1 4: 0
A5PinSet_results_part2 0: 1
A5PinSet_results_part2 1: 0
A5PinSet_results_part2 2: 0
A5PinSet_results_part2 3: 0
A5PinSet_results_part2 4: 0
A5PinSet_results_part2 5: 0
A4PinSet_results_part2 0: 1
A4PinSet_results_part2 1: 0
A4PinSet_results_part2 2: 0
A4PinSet_results_part2 3: 0
A4PinSet_results_part2 4: 0
A4TEST: 0
A5TEST: 0
A0-4: 1023
