If you can see the photo - I need to identify the connection on the right side with the blue wire.
The other is one I ordered from sparkfun (sen-08733) and it is incorrect for my board - I asked them via email - they said bring it here. Apparently mine is JST-XH (2.5) but it has the little blades on the sides - not smooth. idk
Any help is much appreciated
Sincerely, JS
PH is the suffix for connectors that have tabs/wings on the side (“Positive Housing Lock”); if the spacing between pin holes is 2.5mm your connector is likely a 2.5mm JST-PH…although I’m not seeing much that look exactly the same as yours
It might be custom-made connector :-/
Keep in mind you can always you grab some snips and “edit” a connector’s plastic to fit a given housing ![]()
