I am looking for a ribbon type led in attached pictures. I am looking to change the message it is creating either mobile via Bluetooth or wifi. There is an Amazon product that is close to what I am trying to do but it’s a fixed message and not able to be changed. The ribbon will move on its own so I will not need a motor but it will need a battery still. Let me know if you need anything else.
Option two would be use this ribbon and find a led controller that I can use to change the message.
Hi Kyletho.
I’m afraid we don’t carry a LED ribbon like the one in your picture. We also don’t have a controller for something like that, but we do carry a product called the [Pro Mini that you could use to build your own controller if you know how to write the software that creates the message you’re looking for. (Sadly I don’t have any example code or a tutorial for something like this.)
I did find a tutorial online that might be helpful though. See the link below.
https://maker.pro/arduino/projects/arduino-pov-display](https://www.sparkfun.com/products/11114)
