Hi all,
I’ve recently purchased an olimex h-2294 header board (LPC-2294). However, I have been unable to get the LED flash demo to run.
I built the sample on olimexs site with the eval version of IAR.
It seems to upload fine (Philips flash utility), but I don’t see anything.
I’ve also installed a complete cygwin hosted gnu toolchain based on Jim Lynch’s tutorial. Once again the modified 2106 code builds and uploads fine but it won’t run.
Does anyone have a sample intel hex file that will run on the h-2294 so that I can confirm my setup’s ok. I’d also like a sample gcc makefile and linker scripts for a flash test prog so that I can confirm my code’s ok.
Cheers,
Steve
