I’ve recently migrated by robot project from using a serial GPS to a I2C XA1110. The problem is that I can’t see to get the I2C XA1110 to scan satellites with my own code. Works when I use an Arduino project, but not with a Jetson Nano using I2Clib and some c++ code. I can parse out the date and time, firmware version and everything, but the $GPGSA or $GPGSV strings always read out
$GPGSA,A,1,*1E
$GPGSV,1,1,00*79
I’ve tried enabling with
$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28
but with or without the $PMTK314 command I get the same results
I could use some guidance on how to proceed and/or debug.
Thomas.
