HotAir Station 303D Error C-E
I own a 303D hotair station. Unfortunately, the unit doesn’t work and shows a “C-E” error message. The unit seems to still be heatig, but no air is coming. Is there a specifical part that is dead or is it another problem?
thanks
https://learn.sparkfun.com/tutorials/ho … leshooting After poking through our guide I don’t see any mention of that error, but since the air isn’t working and the heat is I would suspect the pump is/has failed? If you are comfortable with DIY I’d recommend opening the case (safely!) and testing the air pump and replace if needed
