I purchased Sparkfun’s kx134 sensor. And I want to use the ‘Low Pass Filter’ to reduce the noise of the accel value of this sensor. Is there a way to do this in the library?
Or is there any other way to filter?
Thank you.
Thank you.
“User-configurable 3-stage Advanced Data Path (ADP) with low-pass filter, low-pass/high-pass filter and RMS calculation engine” . But can’t find in the manual how we can configure. Hope team sparkfun will come up with a suggestion.
Hello, thank you for your answer.
If so, can’t you be provided with a way to filter this sensor? (I use Arduino)
