I have a standard Prolific USB to FTDI cable I bought for interfacing with a wifi router. The Lilypad should work with this right?
It has 4 wires. Red-Vcc, Black-Gnd, Green-Tx, White-Rx. I keep getting a sync error when trying to load the sketch.
Is there maybe a serial port speed problem? I have switched the Green and White wires around. Even tried starting the upload and resetting the Lilypad.
Or, do I have to order the special breakout board for the Lilypad?
With all or just the red and Black wires attached, I can reset the Lilypad and see the LED start flashing and speed up until it goes out.
Any help would be appreciated.
Scott
