Please help, since I’m frequently testing and debugging code, I’m hope that it won’t be useless in a near time.
thank you
thank you
Hey Ron,
You’ll need to read the datasheet for the MSP430F149. Internal FLASH memory usually has a lifetime of atleast 100,000 cycles if not more. These are conservative numbers as well. The number of writes before a single gate failure is usually much higher.
I’ve been reprogramming flash micros for years and I’ve always managed to destroy the chip or moved to a different design before I wore out the internal flash gates.
-Nathan
