How could I amplify the output for Gyro/Accelerometer sensor combination (IMU) to 0-5v or 0-10v range without using an arduino or other micro controller?
I’m planning to use Gyro/Accelerometer sensor combination (IMU) but the output analog voltage it’s quite small for the device that it will connect to (a PLC for a industrial application)
Generally some op-amp circuit would be used. SF sells a couple of break out boards (BOBs) that might work for you, with little to no modification … or you can spin your own if not. Without knowing which IMU and what the max output levels and desired input levels to your PLC (and noise and bandwidth requirements) it’s hard to make a recommendation.
Mee_n_Mac:
