hi, all!
I want to set up my Digimesh with sleep mode. As in datasheet, Xbee digimesh support two sleep mode, synchronous and asynchronous. I configed xbees in asynchronous sleep mode with pin wake up (SM = 5). Unfortunately,Xbee can’t receive the data from the others. Could any one show me how to config them?
Thanks a lot!
PS: Sorry for my English
When using DigiMesh you generally want to be using the synchronous mode (SM=7,SM=8). When you are using asynchronous mode nodes are not able to repeat in a Mesh topology.
If you still wish to use asynchronous mode, set both nodes to SM=5 and also CE=2 on both devices. You should be able to exchange data.
Good luck!
I saw you posted over in the Digi forum too (http://forums.digi.com/support/forum/vi … read,10204).
