I think I brick my Xbee and I would like to revive it back!! the only hardware I have with me is
RS232 dongle from http://www.eflightworks.net/products.html
and bricked Xbee
How can I fix it without using the explorer board!?? ![]()
and bricked Xbee
There are several threads in this forum that has be-bricking info. Please do a search and some reading.
waltr:
I did search in b4 posting this topic. Mostly is using the USB explorer board which I dun have and another method is to use hex inverter chip which I also dun have. That’s why I wanna know if there’s a method to unbrick Xbee using rs232 only.
The un-bricking technique is nearly the same whether you have a USB or RS232 interface.
The one item that is needed is a RESET button to the XBee reset pin.
Did you find the thread titled “Better XBee documents” with links to more info? In there is this link:
