How to increase the Record Limit of Arduino Extended Databas
Dear all,
I am using the Arduino Extended Database Library in my arduino sketch. In the website of
http://playground.arduino.cc/Code/Exten … aseLibrary, it states that it can support a theoretical maximum of 4,294,967,295 records (unsigned long). However, in my sketch, I write the following code to define the table size to be 30000. I use MicroSD card as the memory. Actually I use the example EDB_SDCARD in the Arduino Extended Database Library. The codes are as follows. Thanks!
#include <SPI.h>
#include <SD.h>
#include "max6675.h"
#include <SoftwareSerial.h>
#include <Wire.h>//import necessary libraries: SoftwareSerial, Wire
#include <DS3231.h>
#include "Arduino.h"
#include <EDB.h> // for database and SD card
#define SD_PIN 4  // SD Card CS pin
//#define TABLE_SIZE 8192 // for database and SD card
#define TABLE_SIZE 10000 // for database and SD card
// Init the DS3231 using the hardware interface
DS3231  rtc(SDA, SCL);
SoftwareSerial I2CBT(9,10);//define PIN9 and PIN10 as RX and TX
int ktcSO = 2;
int ktcCS = 3;
int ktcCLK = 8;
MAX6675 ktc(ktcCLK, ktcCS, ktcSO);
const int soilMoist = 0;
// const long int recordPeriod = 43200000; // 12 hours
const long int recordPeriod = 1000;
char val; // variable to receive data from the serial port
char* db_name = "/db/edb_test.db"; // path of db files in SD card
File dbFile;
int logid; // variable to store id of log
// Arbitrary record definition for this table.
// This should be modified to reflect your record needs.
struct LogEvent {
    int id;
    String logdate;
    String logtime;
    int temp;
    int soilmoist;
logEvent;
// The read and write handlers for using the SD Library
// Also blinks the led while writing/reading
void writer (unsigned long address, byte data) {
    dbFile.seek(address);
    dbFile.write(data);
    dbFile.flush();
byte reader (unsigned long address) {
    byte b = dbFile.read();
    return b;
// Create an EDB object with the appropriate write and read handlers
EDB db(&writer, &reader);
void setup() {
  // Open serial communications and wait for port to open:
  // Initialize the rtc object
  rtc.begin();
  // The following lines can be uncommented to set the date and time
  //rtc.setDOW(SUNDAY);     // Set Day-of-Week to SUNDAY
  //rtc.setTime(9, 1, 0);     // Set the time to 12:00:00 (24hr format)
  //rtc.setDate(31, 7, 2016);   // Set the date to January 1st, 2014
  I2CBT.begin(9600); //藍牙 BAUD RATE 9600
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  if (!SD.begin(SD_PIN)) {
      Serial.println("No SD-card.");
      return;
  // Check dir for db files
  if (!SD.exists("/db")) {
      Serial.println("Dir for Db files does not exist, creating...");
      SD.mkdir("/db");
  if (SD.exists(db_name)) {
      dbFile = SD.open(db_name, FILE_WRITE);
      // Sometimes it wont open at first attempt, espessialy after cold start
      // Let's try one more time
      if (!dbFile) {
      if (dbFile) {
          Serial.print(F("Openning current table... "));
          EDB_Status result = db.open(0);
          if (result == EDB_OK) {
              Serial.println(F("DONE"));
          } else {
              Serial.println(F("ERROR"));
              Serial.println("Did not find database in the file " + String(db_name));
              Serial.print(F("Creating new table... "));
              db.create(0, TABLE_SIZE, (unsigned int)sizeof(logEvent));
              return;
      } else {
            Serial.println("Could not open file " + String(db_name));
            return;
      } else {
        Serial.print("Creating table... ");
        // create table at with starting address 0
        Serial.println("DONE");
  recordLimit();
  deleteAll();
  // read sensors and append to the string:
  int sensor;
  String ltime;
  sensor = analogRead(soilMoist);
  logEvent.id = logid;
  logid = db.count()+1;
  //logEvent.logdate  = rtc.getDateStr();
  logEvent.logtime = rtc.getTimeStr();
  Serial.println("TIME"+logEvent.logtime);
  logEvent.soilmoist  = sensor;
  logEvent.temp =  int(ktc.readCelsius()); // temperature sensor data
  EDB_Status result = db.appendRec(EDB_REC logEvent);
  if (result != EDB_OK) printError(result);
  Serial.println(F("Append 1 record"));
  delay(5000);
  delay(5000);
  selectAll();
  dbFile.close();
void loop() {
  // make a string for assembling the data to log:
  String dataString = "";
  byte cmmd[20];
  int insize;
  if ((insize=(I2CBT.available()))>0)
  {  //判斷有沒有訊息接收
    dataString += String(insize);
    dataString += ",";
     for (int i=0; i<insize; i++) {
       cmmd[i]=char(I2CBT.read());//將接收的訊息顯示出來
       dataString += cmmd[i];
       dataString += ",";
  delay(1000);
void recordLimit()
    Serial.print(F("Record Limit: "));
    Serial.println(db.limit());
void countRecords()
    Serial.print(F("Record Count: "));
    Serial.println(db.count());
void printError(EDB_Status err)
    Serial.print(F("ERROR: "));
    switch (err)
        case EDB_OUT_OF_RANGE:
            Serial.println(F("Recno out of range"));
            break;
        case EDB_TABLE_FULL:
            Serial.println(F("Table full"));
            break;
        case EDB_OK:
        default:
            Serial.println(F("OK"));
            break;
void selectAll()
    for (int recno = 1; recno <= db.count(); recno++)
        EDB_Status result = db.readRec(recno, EDB_REC logEvent);
            Serial.print(F("Recno: "));
            Serial.print(recno);
            Serial.print(F(" ID: "));
            Serial.print(logEvent.id);
            //Serial.print(F(" Date: "));
            //Serial.print(logEvent.logdate);
            Serial.print(F(" Time: "));
            Serial.print(logEvent.logtime);
            Serial.print(F(" Temp: "));
            Serial.println(logEvent.temp);
            Serial.print(F(" Soil Moisture: "));
            Serial.println(logEvent.soilmoist);
        else printError(result);
void deleteAll()
    Serial.print("Truncating table... ");
    db.clear();
