How to Interface wireless camera with ZigBee
Dear Sir…
My thanks in advance to you for your valuable suggestions and guidance, with your kind advice only last year I was able to design a communication link between computer and target vehicle controlled by MATLAB.
Now I am trying to upgarde the target with wireless camera interface using ZigBee, if I get any method available for interfacing wireless camera with ZigBee, please share your suggestion to me Sir…
Thank you
Babu
Use a low Baud rate, 57.6k or less, asynchronous serial camera and connect to the DIN pin on the XBee.
Any data rate faster than this won’t work.
babupg:
Dear Sir…
Thank you
Babu
Wireless video on robotics platform: by all means, go for analog video, say, one of the 2.4GHz low cost video-senders. Need frame rate and quality - not possible with low speed data.
(be sure to distinguish ZigBee ™ from IEEE 802.15.4, much as you distinguish TCP/IP from 802.3).
