Hi!
I am trying to design a board, which needs solder mounted heatsinks on top of some SMD mounted transistors.
I have created a polygon on the top layer, which is where the heatsink will be soldered to, but I’m pretty sure that polygon will be covered by a solder mask, when I send the board to production.
Is there any way to prevent this from happening?
Thanks a lot in advance!
