How to Measure Blood Pressure using SparkFun Pulse Oximeter and Heart Rate Sensor - MAX30101 & MAX3
I am trying to measure BPT - Systolic Diastolic pressure using SparkFun Pulse Oximeter and Heart Rate Sensor - MAX30101 & MAX32664 (Qwiic).
I reviewed code from the - https://github.com/sparkfun/SparkFun_Bi … ub_Library and there is code comment on .cpp file
// ------------------Function Below for MAX32664 Version D (Blood Pressure) ----
The Example code users readBPM() method but not sure How do I measure Pressure values?
void loop(){
body = bioHub.readBpm();
Serial.println(body.heartRate);
Thank You,
Nim
We don’t have a ready-made example for that revision (D), but see line 1195 or so here https://github.com/sparkfun/SparkFun_Bi … ibrary.cpp for the functions/registers and page 6 here https://www.analog.com/media/en/technic … 32664d.pdf for specific info
I don’t see how it’s possible to calculate blood pressure from pulse rate and blood oxygen levels. I think this sensor could be used in conjunction with a pressure sensor to do that but by itself I don’t think it’s possible.
