How to measure voltage using microcontroller
Hi there,
How to measure voltage using microcontroller? any tutorial? book? sample projects? codes et ct? Thanks
Voltage range, accuracy?
Leon
leon_heller:
Leon
The pH electrodes outputs voltage signals in the order of milimeter. I want to be able to detect that.
But in general I want to know how to measure just voltage using codes and controller.
Most AVRs have an ADC, it’s quite easy to use.
You’ll need an amplifier for the output from a pH sensor.
Leon
This thread has some links to op-amp designs for pH probes. The probes are very finicky due to their 10MOhm+ resistance.
http://reefcentral.com/forums/showthrea … id=1496284
theatrus:
Thanks all for responses. However my original question still remains.
How to measure voltage using AVRs? Thanks
You use the ADC. It should be covered in the datasheet.
