Hello everyone,
I would like to know if anyone can help me with the problem I am having with my PWM design with Arduino nano.
I want to design a PWM dimmer with 20KHz on Pin 9 of Arduino nano 328. I want the resolution to be 256. I also want to use PWM on other pins using “analog write” instruction.
I am using “Arduino PWM frequency Library V_04” library. During the testing, it works properly, but when it is used in the main firmware, it stops working and constantly gets the micro-controller locked.
I guess this might be due to some inconsistencies in using the hardware and the timer. I am using the following instructions:
wire-delay()
analogwrite()
Serial.Read()
Seiral.Println
Can you guide me what the problem might be?
Regards,
Norman
