I have finally got my JTinyUSB from Olimex to work with LPC2103 development kit. I encountered only one problem, I could not figure out on how to select binary file to be flashed into ARM microcontroller. Is there a way to do this by passing argument ? so I can modify flash script as showed below
flash command-“batch”
adapted by Martin Thomas based on information from Dominic Rath -
sleep 500
halt
wait_halt
poll
flash probe 0
flash write 0 %dmain.bin 0x0
#or flash write 0 %d%f 0x0
#reset run
#sleep 500
#shutdown
#where %d is pathname for the file.
#where %f is filename for the binary file
Thank you
Dillip
