Hi all,
I’m Théo and I’d like to use a **[SMD Module[/b] for a school project.[/u]
Actually what I have at the moment is :
[u]an [electric signal] which goes in a __[[µ-processor][/b] which converts the voltage in a [new value] which is sent thanks to a [USB serial connection] to a [laptop] which uses the [new value] in a [software] to make different things in function of the new value.__[/u]
[u]__This, is working ! :)__[/u]
[u]__But, I must do more ! I must replace the [USB serial connection] by a [Bluetooth serial connection] …[/u]
[u]So, here I need your help to know how to use a SMD Module which is obviously used for Bluetooth communication.__[/u]
[u]__On my µ-processor, I have a lot of pins (Rx, Tx, RST) and on my Bluetooth SMD Module, pins Rx, Tx, RTS, CTS and RST are available… But I don’t know which one I need to connect with… :([/u]
[u](All the documentation I have is very light, it is the one available on SparkFun, I don’t have any examples of circuits)__[/u]
It would very nice if you could give me some help because I tried to set up a communication between the µ-processor and my laptop thanks to the BT module, me laptop can see and be paired with the BT module, but when I try to read the value hich is sent, nothing is read !
[u]__All information may be interesting :D**](http://www.arduino.cc/en/Main/ArduinoBoardPro)__](Bluetooth SMD Module - SparkFun - WRL-08474 - SparkFun Electronics)[/u]
