How to use ARM RealView with Olimex P2148?
I’d like to use ARM RealView with Olimex’s P2148 kit. I downloaded and set up H-JTAG, however, when I try to load a file in RealView Debugger, I get the following error: `Error S0025 (server): unable to write memory at specified addr while loading file’. I assume this is because H-JTAG can’t program LPC2000 microcontrollers yet. If so, is there any other solution that would work in my setup (ARM RealView with Olimex P2148)?
Décio
