I just bought ‘Coin Acceptor - Programmable (6 coin types)’ and tried to make some programs but I enfronted some issues while trying to connect it to the Arduino UNO processor.
first, is the program called Realterm necessary in order to sort the coins?
second, if not, how can I make the device to be connected with Arduino UNO and show signals on the serial monitor?
I want to get some information about how to receive and interpret signals on Arduino skectch software using some codes.
(I made the device to recognize 4 different types of coins after watching videos though.)
I will look forward to hear your response.
Thanks a lot.
If you want to connect it directly to a PC you'll need a USB-TTL serial converter and some terminal emulator program. That could be Hyperterminal instead of Realterm if you want.
To connect to an Uno I would use the pulse output, connected to a digital input pin. I believe the 6 coin machine outputs a different number of pulses for each coin type. So have the Uno count the pulses and do a “print” to the serial monitor of that number and/or the associated coin value.
