I purchased a Qwiic alphanumeric display and cable to use with my Redboard Qwiic. My first attempt at the sample programs and one of my own worked well. After that I had intermittent results with more failures than successes. Examination of the connectors with a magnifier shows a possible bad connection to the VCC lead. Is there a way to test the cable or bypass wires to find the problem?
I am not sure about the pin size. Can you connect Male to female jumpers to the pins of the quiic connector? If you can, you can test the display separetely.
Fill in the form on the page below and SparkFun should be able to help.
