I2C can't detect my AS7343 module
My problem:
· I2C scan cannot find AS7343 (address 0x39)
· But AS7341 works fine with the same wiring and ESP32-S3
· I’m using SparkFun AS7343 library, but sensor fails to begin
I2C can’t detect my AS7343 module, but AS7341 works on the same setup. Is my AS7343 broken or is there a driver issue?
Can you share a photo of the wiring?
Are you trying to use both at once?
