I2C/LabView/MPL3115A2 Altitude Sensor
Hi everyone, I am using the MPL3115A2 altitude sensor for some pressure measurments, however I am running into some troubles as I am not getting any data readings.
Here is the overview of what I am trying to do:
  • connect the sensor to an arduino
  • connect the arduino to LabView
  • use the I2C read pathway and other LabView extensions
Has any one used this sensor and read its data with LabView via Arduino and had success? Any help would be greatly appreciated!
https://www.sparkfun.com/products/11084 <----- link to sensor
We can’t help with the LabView portion of your project, but the [hookup guide for this sensor will help get it connected up to an Arduino and there’s some sample code there that should at least get things up and running.
Good luck with your project!](https://learn.sparkfun.com/tutorials/mpl3115a2-pressure-sensor-hookup-guide)
