Image file over LORA RFM95
Using an arduino and a serial camera I can capture and save a very small jpg image to a sd card. I need to send this image to multiple locations at the same time. I have the Radiohead example that does not use error correction working between one server and multiple receivers. I can read the jpg image from the sd card on the arduino that operates the transmitter to multiple locations. I am looking for example code to send the image file and write it to an sd card on the receiving end.
Hello, and thanks for writing.
Unfortunately I don’t think you’re going to find example code for such a specialized case like this. Unfortunately SparkFun can’t assist with your request, but the community might be able to help you.
