IMU 6 DOF module: what is the input voltage range?
i am using a “IMU 6 Degrees of Freedom - v2 with Bluetooth/ADXRS300” module ( http://www.sparkfun.com/commerce/produc … ts_id=8188 ). the pcb board says: ‘>5V’ as a valid voltage. but what is the highest possible voltage without destroying the device? will it work also with 9V ?
roman
