SparkFun Air Velocity Sensor Qwiic Kit - FS3000-1015 not providing the correct raw data values when connected using Qwiic connector to Artemis Nano Board
There’s a note for boards that use the Apollo core (which the Artemis does); are you set to 400KHz? Air Velocity Sensor Breakout - FS3000 Hookup Guide - SparkFun Learn (search for ‘apollo’ in the page to see the note)
Do you have another i2c device you can test?
