What you are looking for is called an H-bridge and you can find many single chip solutions. For small signal applications, an analog switch can also be used.
[edit] it also occurs to me that a quad NAND gate would also work: 74HC00
How quickly must the ?device? respond to a change in it’s input ? How much current must the 2 outputs be capable or sourcing and sinking ? Is there an implied ground wire also being input to the ?device? ? Or must the ground reference for the input be one of the output lines ? Put another way, is it truly a 3 “wire” device or 3 wires plus ground ? Do you prefer lowest part count over size, cost, reliability ?
OK, back to this again - not really as simple as it seems…
In the original question, there is a SINGLE input, that can be at +5 or 0V - but TWO outputs that flip back and forth between +5V and 0V depending on the input.
Of the three proposed solutions, only the DPDT Relay achieves this using a single input. (I assume the the cylinder in the image is an inline current limiting resistor for the 5V supply?)
The H-Bridge, and the NAND (or multiple NAND) Solutions both require more than one input.
SO -
How can i reproduce the dpdt relay as a no moving parts solid state component? (preferably SMT).
Or to fix the H-Bridge and NAND solutions - what would go between the single input, and the two inputs needed for the NAND/H-bridges?
t3kboi:
Again it all comes down to how much current this circuit has to be able to source and sink. As mentioned above one output *could* just be a wire from your input, while the other is simply an logic inverter. If a 7404 can't provide the current needed, perhaps this would do ...
