Inquiries regarding product_GPS-17285
I am interested in your prodduct SparkFun GPS Breakout - NEO-M9N, SMA (Qwiic) (GPS-17285) and would like to confirm some technical details. I plan to only buy this product not others.
1. ‎Is it possible to measure distance by transmitting and receiving signals via Wi-Fi or Bluetooth with an ESP module? If so, what is the maximum distance range that can be achieved?
2. I am also considering using a GPS module. Would it be possible to measure distances greater than about 500 meters (for example, across an area larger than a sports field)?
Thank you in advance for your support.
I look forward to your response.
It doesn’t support RTK so sending it data probably won’t help accuracy much. Figure several metres. Even with RTCM3 for DGNSS it’s going to be over a metre.
Range of WiFi in ideal case is a few hundred metres. Not sure of ESP32 but sort of thing you could quantify with GNSS in your own situation / implementation.
Yes, we use this method (called fingerprinting) in rare cases for indoor location tracking.
[Google Quote] Indoor location fingerprinting is a method that uses a “radio map” of unique wireless signal patterns to determine a location indoors.
You can use Bluetooth and WiFi both. As Clive says, several hundred meters can be expected outdoors in a good environment. Obviously you will need stationary sources of RF.
This takes a good bit of work to establish the RF base map, but I’ve seen location accuracies of several meters indoors.
If you need more range you can use LoRa as well (as long as you have line-of-sight!)
