(before i get any flames, im just a 9th grader and a newbie to circuitry, so go easy ![]()
I started circuitry with a “Nerdkit” (from www.nerdkits.com). It has an ATMega168 with a preinstalled bootloader, that lets it communicate with a USB cable (theres also a driver for your computer).
a week ago i hooked up something wrong and killed the microchip :roll:
I’ve ordered two ATMega328’s now, and i want to install my Nerdkits bootloader. I have the AVR conf files changed to support the 328, and I have my breadboard wired up like the “Beginning Embedded Electronics - 2” tutorial. The only problem i have now (im pretty sure) is that i have no clue how to create a makefile!!!
they included the bootloader with all the necessary files in it. Heres the makefile code that was provided in the Nerdkit
AVRDUDEFLAGS=-c dapa -pm168
all: fuses install
fuses:
avrdude ${AVRDUDEFLAGS} -U lock:w:0x2f:m
avrdude ${AVRDUDEFLAGS} -U efuse:w:0x00:m
avrdude ${AVRDUDEFLAGS} -U hfuse:w:0xd5:m
avrdude ${AVRDUDEFLAGS} -U lfuse:w:0xf7:m
install:
avrdude ${AVRDUDEFLAGS} -U flash:w:foodloader.hex:a
(it was all on one line)
The bootloader is licensed under GNU so i could upload the entire thing if it’s necessary. Theres also a seperate text file called “fuses.txt”, if that’s important.
So, can anyone help me get this bootloader onto my ATMega328 using a serial port?
