Hello
I’m using openocd r88-rc1 (http://www.yagarto.de/) and the amontec sdk.
In some cases it seams, the downloaded data of the arm-elf-gdb via openocd is corrupted. With my current elf file I can see this situation a few times. I checked it and it looks like it is the same problem always (mem is ok).
binary data (produced with arm-elf-objdump)
107c: e58d3000 str r3, [sp]
1080: e59f007c ldr r0, [pc, #124] ; 1104 <.text+0x1104>
1084: e59f107c ldr r1, [pc, #124] ; 1108 <.text+0x1108>
1088: e3a02020 mov r2, #32 ; 0x20
108c: e3a03008 mov r3, #8 ; 0x8
11fc: e59b3008 ldr r3, [fp, #8]
1200: e58d3004 str r3, [sp, #4]
1204: e59b300c ldr r3, [fp, #12]
1208: e58d3008 str r3, [sp, #8]
120c: e59b3010 ldr r3, [fp, #16]
openocd log output (bitbang.c and jtag.c lines removed)
Debug: gdb_server.c:814 gdb_write_memory_binary_packet(): addr: 0x00001086, len: 0x00000180
Debug: target.c:623 target_write_buffer(): writing buffer of 384 byte at 0x00001086
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0x00001086, size: 0x00000001, count: 0x00000002
Debug: embeddedice.c:155 embeddedice_read_reg_w_check(): 1
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0x00001088, size: 0x00000004, count: 0x0000005f
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0x00001204, size: 0x00000001, count: 0x00000002
Debug: gdb_server.c:177 gdb_put_packet(): sending packet ‘$OK#9a’
after loading I dump the two areas:
mdw 0x1080 3
0x00001080: e59f007c 7c109fe5 e3a02020
mdw 0x1200 3
0x00001200: e58d3004 0c309be5 e58d3008
Is there a little / big endian problem?
thx for help and ideas
hp.mu
