IP rating of Facet
I was just wondering whats the IP rating of the RTK Facet. I am looking for a receiver which has an IP67 rating or better.
Cheers
Thorsten
“Enclosed Facet Design IP53 - Protected from limited dust ingress and water spray” listed on the ‘features’ tab
If you are looking for a permanent base, consider the RTK Express Kit or Surveyor Kit: https://www.sparkfun.com/products/17370
The antenna is waterproof and a cable (https://www.sparkfun.com/products/17495) will connect an antenna from a roof to and internally located RTK device.
