Error: IR capture error at bit 90, saw 0x042211088442211088442211 not 0x…3
Interestingly, it fails gracefully when I only tell it about 9 of the 10 devices, but fails when I instruct it about all 10
At this point in time I’ve just been trying to have the chain recognised and attempt instructions manually. On our boards with only one device this works like a charm. Falls over when 10 devices are used though
set _CPUTAPID 0x3ba00477
set _BSTAPID 0x16410041
jtag newtap my_dev0 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev0 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev1 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev1 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev2 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev2 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev3 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev3 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev4 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev4 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev5 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev5 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev6 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev6 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev7 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev7 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev8 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev8 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
jtag newtap my_dev9 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag newtap my_dev9 bs -irlen 5 -ircapture 0x1 -irmask 0x3 -expected-id $_BSTAPID
General failure
Open On-Chip Debugger 0.4.0 (2010-11-23-14:20)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.berlios.de/doc/doxygen/bugs.html
400 kHz
jtag_nsrst_delay: 100
jtag_ntrst_delay: 100
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
Info : clock speed 400 kHz
Info : JTAG tap: my_dev0.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev0.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev1.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev1.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev2.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev2.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev3.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev3.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev4.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev4.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev5.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev5.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev6.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev6.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev7.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev7.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev8.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev8.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_dev9.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_dev9.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Error: IR capture error at bit 90, saw 0x042211088442211088442211 not 0x...3
Command handler execution failed
Warn : jtag initialization failed; try 'jtag init' again.
Warn : gdb services need one or more targets defined
And this is the same as above except I’ve #'d out the last two lines of “jtag newtap”
Warn : Unexpected idcode after end of chain: 576 0x3ba00477
Warn : Unexpected idcode after end of chain: 608 0x16410041
Error: double-check your JTAG setup (interface, speed, missing TAPs, ...)
