is the VEML6030 compatible with the arduino due ?
Does the VEML6030 of sparkfun works with the arduino due ?
They should be compatible, but we just haven’t tried the combination yet. The Due should operate at 3.3V, double check the I2C ports are at 3.3V logic level and you should be good to go.
I hope this helps point you in the right direction
