Hello Everyone ,
I tried to connect ARDUINO DUE to ZED-F9P . I use I2C and Your library Sparkfun .
The same systems working fine with Arduino MEGA without problems .
Now I need more math precision and for this reason I tried to use ARDUINO DUE .
ZED and ARDUINO DUE working with 3.3 Volt .
I checked all channel in A. DUE SDA SCL and SCA1 SCL1 but not working .
I Tried to disable the Pull ’ up resistence … but nothing .
Can you test ZEDF9P to ARDUINO DUE and suggest me the correct Wire ?
In your opinion it is necessary some Fix in your library for Arduino DUE .
Your Library is very Complete and I nedd use This Again .
In My opinion Hight Precision GPS required also Hight Precision Math … and I think that ARDUINO DUE math is fine for ZED Family , olso your library is especially write for Arduino Enviroment .
Many thak for your Check and Suggest .
