ISP/Download Utility Problem
I’m currently trying to download code that is more than 64K bytes. I’m using the Phillips Flash ISP Utility. It seems if I download more than 64K of code, it will write back to address 0x0000 after 0xFFFF. I tried to download a small program and it writes fine.
Does anybody know how to overcome this? Or just use a different utility? Thanks.
-John G-
check what HEX format you use
Tsvetan
