Hello, I am attempting to read this card reader with my Arduino’s serial monitor: http://www.sparkfun.com/products/11096
All I get is garbled text when I swipe a card. Each string is always the same for each card, but not the same as other cards.
I have the unit powered and the data pins broken out, I just can’t figure out why the signal isn’t readable text. At first I thought it was because the signals are output from the reader at 3.3V. I tried running the signal through a hex inverter twice to step it up to 5V, but I get the exact same garbage with or without the hex inverter.
Any suggestions? Or questions I can answer to help you help me?
Regards,
Steve
