Jetbot AI Kit JetPack SDK upgrade
I read Assembly Guide for SparkFun JetBot AI Kit and know how to update the notebooks. I want to upgrade JetPack SDK to the latest 4.2.2 which supports DeepStream 4.0.1. The one comes with your SD image is 4.2.1. If I understand correctly, flashing image is the only way to upgrade JetPack for now. In this case, do you have a image built with 4.2.2?
Ben
I think you can update the SDK using these instructions: https://docs.nvidia.com/jetson/jetpack/ … ement-tool
Unfortunately, at this time we do not have a new image built. However, we might be working on a new kit soon… I will use the most up to date tools to build a new image, if it comes through. Otherwise, you can use the [software section of the assembly guide to add our modifications and python packages to the new image.](Assembly Guide for SparkFun JetBot AI Kit - SparkFun Learn)
