I have successfully built the JetBot and have it running autonomously on smooth floors. Thank you for the upgraded caster in the back. Unfortunately, the smooth tires slip on carpet. Is there a part number for knobby tires that will not slip on carpet? Thank you.
Hello Dennis.
A set of [these wheels might work on carpet. If they are too slippery, you might be able to modify them with something more “grippy” like a rubber band or possibly even some small screws to act as studs.](Wheel - 65mm (Rubber Tire, Pair) - ROB-13259 - SparkFun Electronics)
