I’m using the SparkFun jumper library under EAGLE but having problems getting them to route correctly.
There is a keep-out that shows up in the board layout software right around the pads where the trace is to go… I suppose it is there to prevent the router from routing other signals right across the jumper itself… But how do I let the router route the appropriate signals to those pads??
Rudy
