I’ve done a few single sided boards in Eagle and have successfully routed them on my CNC router. I have avoided double sided boards until now…
I have a board with two sides and I use the autorouter to layout the traces. It puts traces on each side and puts the through-holes (vias?) on component legs. This will work fine for some components where you have access to solder both sides (resistor) but not for things like terminal connectors or pin headers where you only have access to the bottom for soldering. How do I tell eagle not to put a through hole under certain components?
