HI all,
I am newer to the arduino community and wanted to know if this is compatible with arduino it is not clear if it is.
https://www.sparkfun.com/products/14947
HI all,
In what way do you mean if it compatible with Arduino? It is a switch so all you’ll be doing is reading when certain pins go “logic high”/“logic low” or show the supply voltage you put in on another pin.
I hope this help point you in the right direction. Thanks for asking.
it is simple switch you can connect any microcontroller or arduino board ![]()
