monis
1
Hi
I am using the trimble lasssen iQ gps module
and was trying to read raw data from it onto my pc
when i run iQ monitor it works fine
but if i try to read data onto hyperterminal it just spews out garbage
can some one help
thanks
ps
i tried all the settings on hyperterminal
baud rates-4800
and 8-N-1
and i believe all the options available none of them gives out the right data
its all abunch of gibberish
monis
2
I am working with the USB development board for the trimble lassen iQ that spark fun ships out
i got the entire starter kit
gm
3
I believe you are looking at the TSIP data. Check the manual
http://www.sparkfun.com/datasheets/GPS/ … -Setup.pdf for setting up the eval board for use with HyperTerminal to see the NMEA messages.
HTH,
Greg
monis
4
hey thanks
i was able to reconfigure the module manually and its working fine
thanks alot
