Hello ![]()
I have been tampering a bit with the code for the keyboart for the lcd shield and would like som feedback on it.
Its working as intended, but im still kinda a noob here so some feedback would be appreciated.
int BTN_read(){
// Function for LCD shield - read buttons
// REQ:
// byte btn_longpress = true; // longpress ability can be turned off
// unsigned long btn_timestamp; // For the timing longpress ability
// int btn_old = btn_none; // For button checking.
if(btn_longpress){
if (millis() >= (btn_timestamp + 1000)) {
btn_old = btn_none;
btn_timestamp = millis();
int _btn;
int adc_key_in = analogRead(0);
if (adc_key_in > 1000) {_btn = btn_none; }
else if (adc_key_in < 50) {_btn = btn_right; }
else if (adc_key_in < 195) {_btn = btn_up; }
else if (adc_key_in < 350) {_btn = btn_down; }
else if (adc_key_in < 550) {_btn = btn_left; }
else if (adc_key_in < 790) {_btn = btn_select; }
if (_btn == btn_old) return btn_none;
btn_old = _btn;
return _btn;
